HID lights and 18" Turbo wheels
Richyd
Could someone give me an estimated cost for fitment of HID lights to a C2S, and also any idea where I could source a set of 993 Turbo wheels as originally fitted to a C2S (BTW, whats the difference between the technology wheel and the turbo wheel - i'm guessing one is hollow spoke and one is solid spoke?)
thanks in advance - Rich
HID lights i had fittted at PCT(autobahn)coventry 6 months ago-about £500 with new clear lenses
huge difference[;)]
HIDs: If you want to DIY just over £100 for a pair. With today's small kits that fit inside the headlights it is a quick and easy job, if you can change a bulb, you can do it. Like Dylan says, it is a must-do change, really does transform night driving outside city. Doing the dips is just about enough in my view. But I might to the main beam as well to see if I change my mind.
You are right on the hollow/solid difference on the 18" wheels. No idea about sources.
[FONT=verdana,geneva"]No knowledge of HIDs or sourcing wheels but I hope this is useful ...
[FONT=verdana,geneva"][blockquote][FONT=verdana,geneva"]How to tell the difference between hollow-spoke and solid-spoke wheels ... [FONT=verdana,geneva"]
[FONT=verdana,geneva"] The hollow-spoke "Technology" wheels have smooth spoke-backs and metal valve stems, while the solid-spoke "Turbo Look" wheels have ribbed spoke-backs and rubber valve stems. [FONT=verdana,geneva"]
[FONT=verdana,geneva"] Here are the part numbers and weights of both wheel types. [FONT=verdana,geneva"]
[FONT=verdana,geneva"] Hollow Spoke "Technology" wheels: [FONT=verdana,geneva"]
[FONT=verdana,geneva"] 993.362.136.00 - ET52 - 19.95 lb (front) [FONT=verdana,geneva"]
[FONT=verdana,geneva"] 993.362.140.01 - ET65 - 23.36 lb (narrow body rear) [FONT=verdana,geneva"]
[FONT=verdana,geneva"] 993.362.140.00 - ET40 - 25.13 lb (wide body rear) [FONT=verdana,geneva"]
[FONT=verdana,geneva"] Solid Spoke "Turbo Look" wheels: [FONT=verdana,geneva"]
[FONT=verdana,geneva"] 993.362.136.01 - ET52 - 25.57 lb (front) [FONT=verdana,geneva"]
[FONT=verdana,geneva"] 993.362.140.04 - ET65 - 29.32 lb (narrow body rear) [FONT=verdana,geneva"]
[FONT=verdana,geneva"] 993.362.140.03 - ET40 - 31.08 lb (wide body rear) [FONT=verdana,geneva"]
[/blockquote][FONT=verdana,geneva"]I believe the C2S was originally fitted with the hollow "Technology" wheels. Strangely, I believe the C4S was not.
If you have the hollow spoke wheels refurbished, please make sure the valve holes are SEALED - otherwsie the blasting medium will get inside the hollow spoke and rim spaces, making wheel-balancing impossible. How do I know? Guess what?
Matthew
_____________________________
Jasmine used to sell refurbished hollowspoke wheels but that was a few years ago. Porsche still sell them but they are v v expensive. They come up on ebay now and then.
Ian.
