HID Xenon lights
- Thread starter charles.y
xenon
I think if you use a dip-only H4 bulb then it might be an MOT fail - the auxillary lights on their own will not be sufficient as high-beam due to their mounting position. Furthermore, when you switch to high-beam the dipped beam switches off with H4 bulbs (i.e. both filaments do not light together) so if you use an H4 dip-only bulb the headlamps will go out if you switch to high beam.
I understand also that MOT stations are getting more strict on HID fitments by checking for the legally required washers (which 944s will have) and auto-levelling which they obviously won't.
Mine made a vast improvement but I'd swap back to normal halogen for the MOT.
ChasR
As for getting past the MOT you can do it with the normal lamps if you go for the reflective HIDs where the bulbs will be suffixed HxR (say H4R in this example). Of course for the main beams this is not an issue.
944 man
Cars dont have to have self levelling headlamps. Im aware of the DfT document which makes this mistake, but they dont seem to be aware of the type approved cars which have self levelling rear suspension and the cars whose passenger & load carrying capacities which are insufficient to take the car out of adjustment...
Simon
xenon
Sure......
Perhaps the DfT are unaware of cars without self-levelling suspension (but I don't think so as the document does mention this as being suitable). It may well be that the load-carrying abilities of the 944 are not sufficient to take it out of adjustment but if that's the case why does it have a manual adjusting system? The self-levelling system on my BMW is complicated and expensive. If the DfT document was a mistake then you can bet they wouldn't bother, as indeed they don't in other markets. Every car you buy in the UK with OEM HID lighting will have self levelling lights or suspension.
Mine passed the MOT with a dual-arc H4 bulb with a low-beam shield but I took spare halogen bulbs in the glove box in case the tester got funny but I don't think he noticed.
ChasR
As for not needing dipped headlights I am not too sure (but I know my MOT tester said if it's not there it can't be tested (i.e Reversing lights or MGB rebound straps), but if there they have to work. I know Flashers aren't needed for the MOT.
944 man
ORIGINAL: xenon
A car doesn't have to have headlamps to pass the MOT?
Sure......
No it doesnt. Why argue about something that you dont fully understand?
xenon
A 944 was manufactured with lights, was type-approved with lights and therefore needs to have them.
Why bother arguing a moot point just to be a smart arse?
I do fully understand for what it's worth.
944 man
xenon
If he does fit HID bulbs then the lighting will be subject to the MOT and all that brings.
xenon
I was not aware that the main-beam functionality was not a requirement - I always presumed it was as they always seem to test it whenever I've taken a car for MOT. I'm happy to be corrected if main beam is not required and / or tested.
However if it is not tested, as you say, then the high-beam scatter would not be relevant if you only ever strike the low-beam arc during the test.
DavidL
Lights (it seems), a windscreen, seatbelts in some older cases, a spare wheel, you can ask not to have the brakes tested on the rollers but have the car road tested with a deccelometer etc etc.
Chap I know often pitches up with his 50/60s Loti with an awful lot missing!
Trick is to get an MOT tester who knows this otherwise you will fail and be told to take it up with the powers that be. You will then win but the hassle....
sawood12
There have been several posts from people who have fitted these kits successfully.
944 man
I intend to upgrade the auxilliary driving lamps too, using a cheap H2 kit.
xenon
1) dip only
2) dip and main using solenoid controlled beam mask
3) two arc-tubes (dip and main) in one "bulb"
I used type 3 as each arc is stationary and (hopefully) optimally positioned. This gave me operational main beam and dipped beam, i.e. bi-xenon. The beam cut-off on dipped was very sharp and I never got flashed and passed two MOTs. Not as good as a purpose made projector obviously.
This was the bulb:
![3dc0_1_b.jpg](http://i47.photobucket.com/albums/f159/cazzer_uk/3dc0_1_b.jpg)
