Chaps,
It's MOT-time. Actually, it's a couple of weeks until MOT time, which is quite good news. But I took my car to the MOT place today to have an emissions test done - it always struggles with the CO emissions. I took it the long route to the test place to get the engine good and hot and it was running very well when it arrived.
They did the emissions test first .... and it failed. CO was 3.8, above the maximum of 3.5. It's always high, but I changed the AFM in May for a reconditioned one so I was hoping things would be different this year. Clearly not - the CO was pretty much the same as it was at MOT time last year.
So, what can cause high CO at MOT time? I know it means the car is running too rich - too much fuel or not enough air. However the AFM was new in May, about 3000 miles ago, and the Fuel Pressure Regulator was new about two years ago. The engine temperature sensor was replaced at the same time as the FPR, and the car was serviced around 2.500 miles ago (new oil, plugs and cleaned the air filter.)
I've just fished the plugs and air filter out to have a look at them and the air filter is clean (not obviously blocked, and you can see the light through it if you hold it up to the sun). The plugs look a little sooty, as you'd expect if it was running a little rich.
So what else could it be? What else could cause high CO at MOT time? The options seem to be injectors being grubby with a poor spray pattern, or some kind of fuel pressure issue (rail pressure is too high.) I can get the injectors cleaned for about £50, but am not 100% confident that this will solve the problem. Is there any way of testing this at home, with a good DIY (but not professional) workshop? Or is there any other diagnostic test I should be looking at doing before sending the injectors off?
