High mileage 944S - 391k - which oil to use?
- Thread starter Axl Rose
pauljmcnulty
Time for oil change..i've decided to use mineral oil due to extremely high mileage - 391k -
any ideas which viscosity and make to use?
Is it using a lot? Is there any history of a rebuild?
Nice to see you back BTW! [
Axl Rose
[/quote]
[/quote]
Don't know yet how much it's using..only had the car for 3 days/100 miles..seems to be leaking a bit from somewhere but haven't been able to identify yet as engine could do with a good clean..
Got loads of history starting from day one, even the original invoice dated 1/1/87 from Malaya..£25883.97..
Head gasket, valves, oil seals done aat 314k by Paragon, belts done at 362k by Premier Auto Repairs West Sussex, lots of paperwork still to go through but "investigate non running" and "investigate poor running" are rather common on different invoices over the years..and the engine still seems to be poorly..[&:]
sawood12
ORIGINAL: DivineE
and I wouldn't use a fully synthetic because you cant guarantee its been run on one since new.
No 944 would have been run on fully syth since new. Perfectly fine to use fully synth in fact i'd recommend you use nothing but. The myths of the past wit fully synths are just that - myths. Modern fully synths are far far superior to any natural or semi synth in every way conceivable. They last longer, are more temperature stable, they protect better are more resistant to breakdown from chemical attack etc.
Axl Rose
ORIGINAL: DivineE
Could the dash be reading or have been reading in km previously for that mileage?
Got full service history and it's been in miles since day one..
ChasR
So I'd say whatever the manual recommends. The problem with most 20W50 these days IMO is they are are of very low specs (in terms of API ratings etc) full of seal swellers compared to what they once were unless you go and splash the cash on something quite fancy.
On that basis, I'd personally go for a 15W40 or whatever the invoices say the car was recently ran on.
