The turbo might well be on the way out as that is quite a good mileage for them. You'd also likely find sundry vacuum leaks etc. as the pipes have got brittle over the years and Turbos are worse through having more of them as well as making the intake side of the engine where they all live hot as well as the exhaust side. Aside from that the only Turbo-specific issue I can think of is the wastegate which will at best be weak and could well be cracked causing it to stick either open (poor performace) or closed (way-hey performance until the knock sensor spoils the fun, but at least it won't blow up).
Head gaskets on Turbos are a bit more likely to fail than NA cars, especially if the boost is played with (and there's no point buying one to keep standard as the NA cars drive much better and an S2 is just as quick real-world as a standard Turbo), otherwise it's all the usual corrosion of the sills, brake calliper plate lift, failed engine mount, clutch (more expensive labour to replace on a Turbo, especially an early one, due to the crossover pipe) etc. that you probably already know about.
