High Oil pressure
- Thread starter pincher
ukmastiff
Regards Mas
Northern924
I'd suspect its the sender, gauge very rarely goes wrong, but it can go wrong, see if you can get hold of a know working 2nd hand sender and try it to make sure before you pull out money for a new one
DavidL
As Mas says (I didn't read the first post properly) if the gauge is at 0 with the ignition on but max when started then you could put money on it being the sender. I had exactly that a few years back.
I believe the sender is fairly inexpensive and a DIY job if you are that way inclined.
Mike
pincher
high oil pressure reading,
Battery drain down over 3 day period(with new battery)
Hatch back seals were shot(got gassed out when driving it with window open)
rear window wiper didnt work
sun roof didnt work
radio didnt work
relays missing ??
All seats were shot.
gear lever had loads of play
nice plate though C944.
i wanted a cheapish project,but there was more wrong with her than he said so i walked away,Oh well back to the drawing board.
thanks for your quick answers,and im sure i will find a right 944 somewhere.
