Hmm tempting !
I think these are the Lindsey plates (they look like them anyway). I looked at those before deciding to go the Racers Edge route. The digging I did suggested that the bearings don't last very long and you need to shorted the length of your front strut significantly such that they don't work with some adjustable suspension struts as they don't have enough adjustment to accommodate. I decided to go with RE as they were not that much more expensive ($350), were designed to work with stock non-adjustable struts (not really an issue as I was going with KW, but cerainly didn't want to be in the position where I was struggling to install them), and have a ridiculously highly rated bearing and couldn't find one report on any forum of RE camber plate bearings needing replacing.
A great mod by the way. I noticed no detrimental effect to ride quality and improved steering response immensely.
Theyre one of the few Lindsey items that I liked the look of, but the items in the auction arent Lindsey plates in my opinion. The LR parts have their name on and the adjustments are engraved on one side, whereas these have lines milled in the plate.
There is not such a think like "Lindsey plate". 90% of their parts are from another vendors. If you take your time you can find the same products from another seller, usually a company who originally built those parts and in most cases you can buy products for cheaper price. After all these plates are the most copied item in the market....
I suppose this is the manufacturer of that particular plate:
[FONT=verdana,geneva"] Fastech [FONT=verdana,geneva"] [FONT=verdana,geneva"] 69 Jetland St. [FONT=verdana,geneva"] [FONT=verdana,geneva"] Bridgeport, CT 06605 [FONT=verdana,geneva"] [FONT=verdana,geneva"] 203 - 366 - 5162 [FONT=verdana,geneva"] [FONT=verdana,geneva"] Custom machining and fabrication; billet aluminum suspension components for Porsches for less.
Might be possible Lindsey buy their plates from that vendor
I had a plate design on my mind and a friend of mine designed plates for me excately the way i liked
I had the Racers Edge ones on my old car and found only positives after fitting them.
I think these are Fastech ones
