Hello!
Where the hood latches on (where the interior light is) i have found two bolts under the alarm sensor covers. (1 on each side).
The reason i was looking for these is because it appears i only have 1 bolt holding this bit on!!! Upon further inspection the reason for this is clear, the part that the bolt screws into, which seems to be embedded into the car, has blown apart making it impossible to screw the bolt into it. What's worse is that i removed the other side and the other bolt has also broken up.
The only thing holding the roof on is this one bolt which isn't properly screwed in!
Has anyone got an ideas on this? Is it a common fault with a 99-onwards boxster or even Porsches in general or am i buggered?
Also if anyone knows a good place to get this repaired preferably in Essex i would be extremely grateful.
Thanks,
Roy
Thanks,
Roy
