Neil Strange
Last year my 2.5 boxster 1998 had some water ingress thus the ecu under the passenger seat got covered in water, I removed it and cleaned it all down and left it to dry I then gave it to a ECU specialist who stated that he had repaired some issues inside the unit. The car was then started and it has a massive misfire like its only running on a couple of cylinders, so I replaced the spark plugs and also the coil packs and also the water pump. The car starts fine but the ECU light is on permanently and there is no power but its starts first time. Anyone with any idea help would be appreciated as it has already cost me over £1000 pounds and still not running.
