aka Big Brakes
I finally got my car back today with its new brakes [][]yippee[][]
The story so far has been one of constantly improving the std brakes. If you follow the forum then you will have some idea of what I have done over the past couple of years - new calipers, new discs, race pads, race fluid, remove dust sheilds, duct air thru under a-arm scoop to rotor centre and install hub block-off plates. It works ok but a 1989 G50 car is surprisingly heavy with a tank of gas, 11 litres of oil, sundry litres of windscreen wash, tools and a spare wheels - some 1330kg [:'(][:'(]
While I never failed to stop or had a very soft pedal on the track, the pedal was often disconcertingly long and never inspired full confidence. Now that my car has the full big torsion bar suspension, 225/245 r-compound track rubber and has dieted to the tune off about 50kg it seemed like a good time to give in to the upgrading monster and fork out for some big brakes.
The obvious candidate are 1978-1989 Turbo brakes. With big 917 derived calipers and fat 28/32mm discs they are good for 500hp track cars. But the cost is big once you get the requisite zero offset mounting bells and front discs. You also have to find some Turbo calipers, replace the master cylinder and it really is massive overkill for a trackday 231hp car.
In my opinion the ideal in terms of heatsink and modern stiff calipers would be a 964 brake system or a 944Turbo system. After all, this is what Porsche did when it turned the 3.2 into the 964. I have often looked at 964s 944Ts and thought I would like a set of those brakes. Well, a thought has become reality. After lots of careful research and chatroom trawling I found that VCI (in the US) offer just such a kit - but the price makes you weep. So how do you do it cheaper?
The guts of the kit is a set of 944T front discs (28mm thick vs 24mm for 3.2 and a little larger in diameter) and a pair of 964 or 944T front calipers. VCI recommend you also use a 944T rear caliper on a standard 3.2 rear disc (same 24mm thickness as a 964 or 944T and similar diameter) but this results in a little pad overhang. So time for more research.
First a picture of the new to me 964 front caliper.
