I have a problem with a late 924S, the horn has decided that it will only work on its own terms, and these are sporadic at best. I am sure the fault lies at the interface of the steering wheel and the column. With the steering wheel off I can short the horn mechanism at the top of the column and it works every time (great for the horn, but not practical as steering the car is very difficult![
]) however with the steering wheel in place the horn will generally only work with the steering wheel turned to the left, and only the right hand side of the horn push works. If I then rock the wheel, there is a tiny amount of movement, I can stop the horn working completely. The steering wheel is correctly tightened and fitted. I am at a loss now as what to do. Has anyone any ideas?
