Hot air blower contiuously on
- Thread starter lg58
If so I had a similar problem with a 944 - it turned out to be the ignition switch still making contact. This would sometimes happen after I left the car - and the battery would be flattened.
If you mean the engine fan then ignore above [
Trying to locate a diagram of the blower control unit, but either thats not working, or you have a short.
http://www.dietersmotorsports.com/tech/2001/03-01_911_heater.htm has some info.
It seems as if the control unit can turn on the fan if it thinks the engine is getting too hot, so maybe a sensor is goosed
Remove the cover from the wiper motor being careful to catch any loose bits.
Check that the brushes are in contact with the commutator; The tension on these brushes is achieved by a spring, which is attached via a fibre insulating washer at one end. The washer can fail with age and so releases the tension on the brushes. Replace washer if necessary with a suitable fibre or plastic one of same size.
Try contacting the 3.2 Reg Sec Charles Marsland....01732 848323 He should be able to give you a guide as to what to look for. Good luck.
Have fun
Paul Kelley
Can you let us know how you are getting on with your heating problem? It is helpful to others if you can give some feedback from your investigations. Hope all is well.
Have fun
Paul Kelley
