Re: Porsche 911 (993) 1994 Tiptronic S
(LHD, no mods - standard factory porsche)
I've had the car for 6 months, it was inspected by Mr Morgan, has a solid service history and drives superbly
but my ownership has been blighted by an "˜intermittent' fault.
The symptoms include:
1 From cold engine fires up fine and settles into smooth idle
2 From hot the engine cranks but won't fire (usually after time taken to refuel, approx 5-10 mins)
3 Note: engine starts perfectly when hot within approx 5 mins of stopping
4 If left for 15 mins engine fires up fine and idles smoothly
5 After this event, the engine occasionally stalls on the go "" resulting in painful 15min wait on hard shoulder before firing again!
Fault finding so far:
1 Replaced fuel pump relay
2 Full OBD1 diagnosis with AFN Chiswick: work inc Replaced Air Mass Sensor
Faulty wire in Immobiliser unit (Factory Porsche)
3 AFN had apparently checked obvious things like distributor caps/rotor arm, fuel accumulator, fuel press regulator, ignition module etc
Having spent half my life's savings with AFN, and no nearer finding the source of the problem, I'm hoping that there might
be someone within the club who may have experienced similar problems (or recognise the symptoms)?
It may be worth noting that at my last visit AFN mentioned that a second diagnosis had picked up a faulty
Oxygen Sensor (why this hadn't been apparent at my first visit they were unable to explain). Also can the
Hammer Test identify a fault with the Cylinder Head Temp Sensor? AFN said this appeared OK "" Could these
be causing the problem?
I'm wary of carrying out any more "˜shot gun' repairs and plan to take the car to JZMachtech for a second opinion.
However I would be exceedingly grateful if you could throw any light on the problem before I embark on another series of
costly repairs"¦
Are there any likeminded 993 owners out there who can help?
Huge thanks
Tom
Region 19
Tom Delhanty
28 Langham House Close
Ham Common
Richmond
TW10 7JE
02089402573
PCGB Membership no. 50557
