zwhitea
My 1987 coupe has developed a hot start problem.... Basically the car will start and run fine without any issues what so ever, but as soon as it gets hot... if you turn off the ignition, it refuses to start and the starter just spins but it will just not fire. However there is a smell of fuel from the exhaust. If I let the car cool for 30-60 mins it starts first time and runs fine again until I turn the ignition off again..
And before anyone says.. I have tried a new DME Relay... It has also had a recon ECU less than 12 Months ago..
A couple of specialists have suggested that it could be the sensor on no3 cylinder head.. I have looked in the Bentley bible which details what the sensor should be reading at different temperatures, but am unsure how to actually test this or replace the sensor....
Has anyone out there any ideas or suggestions...
Thanks in advance....
