Hi,
I am sure a lot of people have had this (or have it) but thought I would list the works I have had done to see if anyone can point me to another culprit!
New fuel pump with working non return valve, new accumulator fitted, new injectors (as thought o rings could be perished). Starts very well when cold or starting straight after turning off. If I leave the car over 20 mins (heat soak?) it will not start.
The airflow meter arm does not appear to lift to start fuel flow through when I crank the engine. I can lift the arm to prime the injectors to start.
Taking the car to Le Mans Classic next week and will have to try and fix the issue when I return (hopefully my battery will ensure I can eventually hot start!)
keith
keith
