How can I change....?
Alan_Armstrong
PCGB Honorary Member
I'm going to post this thread on as many registers as i think may be able to help me!
On pre 993 targa and convertible models, there is fitted to the top of the quarterlights a seal/stop for the main door window. Mine are badly worn door to excessive travel of the windows, (badly adjusted to meet the roof seals).
Does anyone know how to replace these 'bits'...I have bought a pair from Porsche Chiswick, but from as far as I can see, the upright support is either welded or riveted in somehow....
Any help on this would be appreciated.
As far as I know the whole 'black frame needs to come out. It will unbolt but is a big job and one that must be done carefully as everything is adjustable. If you do it yourself mark the position of every bolt. If you get another to do it ....hope he does the same.
If it were mine I would do it myself v carefully. Adrian Crawford.
Alan
When I had my hood replaced, a lot of the labour cost was in getting the adjustments right afterwards. Hence my inclination would be to get it done by a specialist. I think Southbound are brilliant, 01264 810080
