how do i lower my front suspension
- Thread starter Guest
If it was me, I would get a shop with corner balancing scales to do it because you are bound to upset your corner weights if you just start fiddling with it. Changing the front ride heights is a 5 minute job but if the corner weights are off and need fixing then (provided you don't touch the rear end) it is probably no more than a one hour iterative adjust and check job. Also, any ride height change will also affect your camber and toe settings so the alignment should be checked. A samll adjustment may not make enough of a change to worry about but a geometry check is certainly best practice.
Richard
Without wanting to offend, but if you don't know what a torsion bar is, you might want to leave lowering the car to professionals. On the other hand, everyone starts somewhere. I suggest you buy some books: Wayne Dempsey's 101 Projects and Bruce Anderson's 911 Performance Handbook spring to mind.
