How do i put this back together (ecu, looms)
midge
How does lot bolt back up? ad where does the door loom plug into?
With a lot of patience!
Most of the plugs will only fit one socket but I would see if there is a local owner who would come over and use their car as a "pattern".
Ill hunt for the other end of the door looms later thankyou, the ecu has a bracket around it, and i think i can find one side where it bolts up, but on the other side there is nothing? and it hits the black plastic covering the thick looms?
Remove the carpet in the passenger foot well. You will find a wooden kick plate angled at 45 degs to the floor remove this and ecu fits behind.
