peanut
Before I go and weld the bottom of the wing to the body I thought that I should check the correct fixing method.
My lower wing is completely unattached from the car along the bottom edge, although it has a lip.
Is this how it should be ?
Looking at the bottom of the inside of a used wing for sale on ebay, it is clear that it was never welded or screwed along the bottom edge !
Is this how it should be ? (see red box )
Does the front wing only fix with the 3x vertical screws leaving the whole of the bottom unattached ? ( see red circle )![944 lower front wing inner.jpg 944 lower front wing inner.jpg](https://www.porscheclubgb.com/forum/data/attachments/1/1104-502f2ba3c1f43a121b2bc8f956be0827.jpg)
