how fast
hi there i have a 1984 2. 5 lux and the top end of the car is only around 120mph (on a track!!!! A1 he he) should it not go faster??? its done 124k miles and its a manual???? i want more speed how could i get this???? apart from buying and s2 or a turbo??? help as i have a need for more speed
on the flat my '83 944 easily has 25mph more ( when it gets close to red i think of how long before the end of the runway, when i last changed the belts and other such thoughts)
I would check for air leaks (the rubber vacuum hose ends are likely to be brittle and hard) and poor sparks, plug leads likely to be leaking if thier original, open the bonnet at night with the engine running.
A compression test might show up other potential nasties.
Less weight = more perforamnce in all areas (except maybe top speed).
A new chip might liberate a few horses as might freer flowing induction and exhaust.
Then its compression ratios / lightened balanced components and diminishing returns.
Turbo is the way to go for relatively cheap power upgrades, you also get bigger brakes, firmer suspension, thrown in.
Tony
there are no leaks but i just think my engine is tyred is there anywhere i can take it to tighten it all back up if there is a way???
As your car is getting to 120 mph I'm assuming it is getting there relatively enthusiasticaly.
Once you get above that sort of speed you are in the realms of high drag and thus require big power to push the car on. You could well find that your car may go faster but it will need a bit of patience.
Whilst Porsche tend to publish conservative figures, they put the top speed of a Lux at 135 mph so you are not a long way short. I don't remember seeing 120 mph down Revett Straight at Snetterton in my Lux so perhaps you are doing well. Even BKE goes like stink to 120 and then seems to start thinking about it and he's reputed to have 300+ bhp [;)]
Porsche graph figures on acceleration indicate:-
2.5 Lux
0-60 IRO 7 seconds
0-100 IRO 23 seconds .'. 16 seconds for that extra 40 mph
0-120 IRO 39 seconds .'. 16 seconds for a further 20 mph
Try looking at the second hand on your watch and imagine the speed increasing. 16 seconds seems like forever, for 20 mph.
By comparison a 220 turbo will hit 100 in 15 secs, 120 IRO 24 seconds, but again tails off requiring a further 17+ seconds to squeeze another 20 mph out.
Based on power and drag, again Porsche figures, the 924S top speed is 2mph higher and 0-62.5 is .2 secs quicker. The 924 is 20kgs lighter but it gains on top speed because it has a lesser frontal area, thus less drag.
I'm afraid you could spend shed loads on your Lux and end up going almost imperceptably faster. At the end of the day, if you want all out power, you will have to do what I did and sell the Lux and get a Turbo. On the other hand, within licence retaining speeds, the agillity, poise, and linear delivery of the Lux makes it every bit as enjoyable as a Turbot.
