How long are parts quaranteed for, from an OPC?
childish
I had my car serviced at a OPC 5 months ago and it needed a lot work on the air conditioning. I have just switched on the air conditioning and its not blowing cold. Does anyone know how long parts or work is guaranteed for, from an OPC?
Thanks for the quick reply I will contact the opc tomorrow to complain about the fault. I didn't take out a warranty this year but I was pretty annoyed to find out that it's not blowing cold after such a short time. You would expect the work to last long then it has done. Obviously after they repaired the air conditioning they re-gased it, how long roughly should a regas last?
Thirded (*?)
My 2000 Cab has never been recharged and blows nice and cold every time. Ok its only done 24k miles but as its a pressursed system I guess it will be just as prone to leaks when its stood.
I suspect that you will have a faulty seal somewhere or maybe even damage. You will need a pressure test to find out the leak and even then you may not find the final cure.
