How many bits have you changed ?
colin944
Here's good game..........
List all the parts you have changed on your car.I don't mean every individual nut and bolt just the parts ie waterpump, All cooling Hoses, and brake discs etc.
I'll start
I'll start.
Body
Floor pan, inner sills, outer sills, intermediate panel, spare wheel well, inner wings front both sides,,bits of rear valance, fog/drive lamps refurbed, all new bulbs inc led tail brake and side lights, door handle and rubbers, door seals, window scraper seals,sunroof seals and tail gate seal, Steering wheel, head unit, a few dash switches
Wheels
Cup 1 7.5 and 9 inch
Suspension
All rubbers inc spring plate rubbers changed to poly , rear shocks, front legs,springs,arb's,arb drop links front and rear. Brake discs all 4 all pads, caliper refurb new ball joints " rennbay kit ", 968 ncastor mounts.All brake lines
engine and gearbox
all top end gaskets inc head gasket, cam chain and tensioner, all belts , water pump, all tensioner, air oil separator, airflow meter,all water hoses,gear box mount, engine mounts, dip stick and tube, windscreen washer motor,all mounts for loom inc all the special tie wraps, fuel lines (changed for stainless braided).
Think that's about it, if there's any more I'll add it in.
ORIGINAL: colin944
Ooh, I think I'm going to have a chance at this game!
Point of order......are we allowed to differentiate between front and rear? E.g. Front discs, rear discs counts as two things changed or just "brake discs" counts as one thing changed whether you changed 1,2,3 or 4?
Pedantry important at this stage....!
Follow my lead. But i have a feeling you'll haves sore fingers after typing out your list.
Haha! Will fire up the PC tomorrow and pull up my cost tracking spreadsheet. No chance of remembering everything right here right now!
I not playing either, my mrs caught sight of the bills a heart attack will be the least of my worries
ORIGINAL: Waylander
Yeah, wouldn't dare! Ana asked me what the bill was when I replaced the gearbox and she wasn't impressed. Didn't dare say that in the four years hVe had the car it's cost over £8k in repairs, maintenance, and deferred maintenance. Andy at Ninex did tell me that it would have been cheaper to run a 911.
ORIGINAL: _ian
ORIGINAL: Waylander
Yeah but you wouldn't want to settle for a 911 when you can have a real Porsche.
I don't have any worries about Mrs M3 seeing this because she paid for most of it anyway so here goes!
Engine:
Cam cover and spark plug gaskets, spark plugs, plug leads, distributor cap, cam chain tensioner pads, cam belt and rollers, balance belt and rollers, PAS belt, alternator belt, oil filter, air filter, fuel hoses, fuel lines, fuel filter, sump plug washer!
Transmission:
CV joints, front wheel bearings, gear linkages, wheel nuts.
Brakes:
Front and rear discs, front and rear pads, all hoses, rear brake lines, all 16 anti vibration pads, handbrake shoes.
Body/chassis:
Both sills, one front wing, engine mounts, one hockey stick trim, both hockey stick gaskets, roof trim strip seals, rear Porsche decal, 944 S2 badge, rear hatch pins, nose panel badge gasket, heater blower cover, bonnet struts.
Suspension:
One wishbone, both wishbone ball joints, wishbone front inner bushes, wishbone castor mounts, front strut inserts, rear dampers, front ARB bushes, front camber adjustment bolts and washers.
Electrical:
Headlights, front indicator lenses, side repeaters, heater blower ballast resistor, heater control panel, one window motor and regulator, power window relay, wiper linkage, boot compartment courtesy light, LCD clock screen, one door lock microswitch.
Interior:
Steering wheel, gear level gaiter, centre armrest.
All of that lot done within the last year and none of it was frivolous. Every part which I replaced was either faulty, broken or worn out. Let that be a lesson to anyone else thinking about buying an "ebay special"!
Next on the list is a top end overhaul so I would expect to add tappets, valve guides, head gasket set and cam chain to the list before too long.
ORIGINAL: Monkeythree
Engine:
Transmission:
Brakes:
Body/chassis:
Suspension:
Electrical:
Interior:
Has your Mrs got a sister [;)]
ORIGINAL: 944Scott
Engine:
Transmission:
Brakes:
Body/chassis:
Suspension:
Electrical:
Interior:
Or two sisters ? lol
Over a few 951's,
all the glass
all the trim
all the dash
all the paint
all the wheel bearings
all the brakes
all the exhaust
all the suspension
all the wiring loom
all the sunroof mechanism
engine / torque tube / gearbox
Head Gasket
Turbo
Intercooler
waste-gate
rack & pump
wings
doors
bumpers
lights
and my favourite of all, the oil filter x 20 at least [8|]
George
944t
