How much does it take to break a 3.3 barrel?
- Thread starter sjd
Good to hear it's almost done Simon, you still sure you've got enough fuel with the CIS for that 3.4ltr motor? I know BW's dyno doesn't log AFR, besides the engine isn't under the same load on any chassis dyno as it is on the road.
Would be good to see the beast when it's done, you still up for a trip to Aylesbury for a run on the old GForce rollers, same issues as with any chassis dyno but at least it logs AFR on a graph for you. I've done some tweaking with mine too, would be good to put them side by side, maybe we can arrange a group thing, I know a few that would be interested, might be fun?
I know there are differing views on fueling. I have made my own observations and have been guided by Bob, who has served me well. We already have the Andial fuel enrichment kit which has been set at position 3 (out of 5) and when turned up to 5 the car runs far too rich and covers the back of the bumper with black soot - I know this as the dial runs anti-clockwise and I had it set on 5 for a short while thinking I had it turned off!
Bob is also to reduce the fuel pressure by modifying the pressure regulator which causes the car to run richer. He is confident we can feed the fuel in - the mechanical CIS was capable of feeding the 934...just not as controlled as EFI systems so I am sure it will run rich at some points. Undoubtedly EFI will produce more power, but I like the "old fashioned engineering" which is why I bought a 1980's car in the first place (albeit 11 years ago!).
I would be interested to do a back to back session with some like minded 930's - that way you get a relative gauge as well an absolute number. G-Force were happy with AFR when we did the 473bhp run, so it will be interesting to see what difference the latest mods make. The car should be back for May, so please suggest some dates and let's arrange it.
regards Simon
I think you'd be better off with a better set up than the Andial for your fuel, there is better management out there for CIS, you can make your WUR adjustable and with the addition of a ignition controlled solenoid you can delay enrichment until it's needed. The Andial enrichment is a bit archaic, and i wouldn't be happy with a fresh engine being managed by it for "on boost" enrichment.
I know you know your onions Simon but you may want to think about other alternatives. BW didn't get on well with 911Addicts adjustable WUR, but that doesn't mean it's the wrong set up, it just means that he doesn't know how to set it up yet. I guarantee once he does he'd swear by it. Just food for thought.
I'll ask around about who's up for a dyno day and get back to you, congrats on getting near the end with your engine, I know only too well what it feels like to go through the arse ache of stripping and rebuilding, look forward to meeting up
If you could make it to the rolling road session, perhaps we could take a look and also establish whether the car is slow, or you are just looking for 1000bhp!!
cheers Simon
50% deposit due 2 weeks before and balance on the day.
Interested? - I will make new post to see if wider group would be up for it.
The difference is that they are fully finned.
George Elliott
Millions of tonnes of pressure at 20 deg C I guess. Some genius could calculate it exactly perhaps.
In the application where its producing 475bhp with correct A/F Ratio it should not fail, but from your excellent images, there is an area on the outer surface near the top, which looks to have been exposed to intense localised heating. The crack perhaps originated from that. I vaguely recall reading that an exhaust can fail and concentrate heat from that failure in a way that could cause this.
Better luck in future
George
944t
964
The car had been fine with 4 speed box with low ratio ring and pinion for general road use - the failure occured after I had fitted 5 speed box and was able to hold revs for longer and hit limiter in 5th....at this point the engine will have been producing maximum heat!
...gave me an excuse to upgrade further so let's hope this time it survives longer...
