How much paint.
- Thread starter 944Scott
PSH
If your painting yourself, you'll need panel wipe, marked mixing cups, stirrers, rag cloths, mask, (ventilator if using 2 pack) , a well-ventilated workshop with very good light, I can't emphasise how important good light is. If metallic you need to try and use the gun at the same angle/distance for each pass, also an old trick is to put a couple of ball bearings into the cup to keep the paint mixed.
I've probably forgotten much but this should give you an idea of what's involved...oh nearly forgot, spraying equipment used other than the gun will affect the finish greatly, good compressor with large tank, filtered is important...lastly, plenty of practice before starting, never spray the car with a fresh cup full without testing it on a piece of card first.... btw this goes for all spraying, not only cars....
regards
Pete
blade7
Well-known member
PSH
Monkeythree
