How Remove Bumpers
- Thread starter mintmate
Open up the indicators disconnect the wiring here and push the cables through the rear of the lights so that they are unattached when you take the bumper off.The long lateral rubber at the front of the bumper has a screw at either end,unscrew these.Ease the long rubber off the bumper,this is held with nylon poppers which push into a series of sleeves on the bumper{7 or 8 i think wise to renew these.}With the rubber removed you will then see the 4 locking nuts which hold the bumper onto the impact shocks.Before you remove these disconnect the bellows at either end .As yo ease the bumper off you will have to disconnect the hoses from the washer jets.
Back Bumper
Loosen the no plate lights and pull off terminals as the cables will have to pull through.Loosen off the bellows held by 5mm nuts on the inside.
To gain access to the nuts which secure the bumper {same idea as front}you will have to remove the corner rubbers.There is a small rubber pellet on these at the over rider side of each rubber,pop these out and there is a self tapping screw in there.This was seized solid on mine but as i was renewing all the rubbers i just ripped it off.The other side of the corner rubbers is bolted through but as you have now exposed the lock nuts which hold the bumper on they can wait for now.
Now disconnect the earth wiring on the fog lights.
Remove bumper lock nuts it should now pull off.
phew wheres that kettle.
Funny trevor your taken them off and heres me just put mine on.
Im guessing youre gettin them painted?
Trevor I ve just done everything from the bottom of the wings down and also the cills, what a difference it makes really sharpens the car up,done all the rubbers to.
EDIT: I had a look today and it would seem the best way to remove the valance is to remove the whole bumper assy complete.
alex.powell
Thats a good post on bumper removal, i'm not sure how posts end up in the Techinical Articles section, but yours would fit nicely in there...
alex.powell
