How the devil do you remove the speedo?
- Thread starter Beaky
Push it through from the luggage compartment mate. I have used an umbrella in the past, I didn't want to scratch the back of the gauges. As advised it doesn't matter if you push the wrong one, it will help with access.
REAP do a brilliant job, the white dails nicely off-set the Linden interior and black exterior and the LED add a tint of blue to the illumination.
This is a well worth upgrade for those thinking about it
cheers
I don't see any need to lube the rubbers for the instruments though. If they are hard to fit then I would just use a little water before using grease.
