AVI_8
My wear sensors have been illuminating intermitently, though the pads need changed, they were doing it long before that, seemingly it's a common fault, I'm going to do away with them altogether.
My plan is to upgrade the brakes on my car next year, it's a Carrera 2, which has the smaller 2 piston rear calipers, hopefully I'll be able to source a pair of larger front calipers, then use the current 4 piston front ones on the rear after a small modification.
I'll replace the disks then with uprated ones.
For now though I'm just going to replace the pads all round, back ones first, firstly remove the locking pins, one from each of the pad mounting bars.
Next use a punch to gently tap the 2 securing pins inwards.
My punch tapered out, so I sacrificed a small diamiter screwdriver to push them far enough back until they were loose enough to pull out.
Once both of the pins are removed, use a large screwdriver to gently lever out the pads, give the area, a good clean with brake cleaner, then you need to push in the pistons, I use 2 large flat blade screwdrivers to do this, use the disc to lever against (it should only require a small amount of pressure (take the lid off the brake fluid reservoir first) push the piston right back in using even pressure at opposite ends of the piston, I use a small piece of wood, to stop the other piston from being squeezed out whilst doing this, or you could use the old pad.
put some copper grease on the sides of the new pads where they seat, and on the back face where the piston will have contact.
It looks like I've used loads on the above pic, the flash has exagerated it, there was only a small smear
Clean the pins with some sandpaper or something abrasive, then smear some copper grease on them.
Before and after here
Insert the new pads, fit the metal bracket unter the pin, slide in the pins with the hole for the locking pins pointing outwards, tap them home gently, and dont forget to fit the small locking pins. Job done
