AVI_8
This should be a simple job.......should be but mine wasn't.
I had a tear on the gaitor (inner nearside) so bought new boots for both the inner and outer, If you've got the CV joint off it would be silly not to replace both while youre at it.
Got mine from Euro car parts, the kit was quite comprehensive, came with boots, clamps, grease, circlips and covers, some of the cheap kits only come with the rubber boot.
First job to do is to support the car properly, you'll be lying under it, get it as high as you can or it will be more difficult, and use proper stands, don't lie under a car supported by a jack!!
Take the car out of gear and put the handbrake on and remove the inner 6 bolts holding the driveshaft to the gearbox, hyou'll be able to remove 3, then release the handbrake and turn the driveshaft until you can get the remaining 3, I used an allen key with a spanner over the end for extra leverage. From the pic you can see the tear in the gaitor and the bolts you have to remove.
Now remove the bracket to allow the driveshaft to drop free, You may or may not have one on the other side if you're doing the offside I havent looked.
Pic of bracket,its 2 bolts
Once you've done this the driveshaft can fall free and you'll see this,
the metal cover on the end can be chiselled off (carefully if your CV kit didn't come with a new one, mine did), when it's off you'll see this.
Make sure you're wearing overalls as it's a mucky job!, I used lots of rags to clean the area, and remove the old grease, you'll need a pair of circlip pliers to remove the circlip.....Don't forget to do this or the CV joint won't come off!
Once thats done, and if you're lucky, you'll be able to tap off the CV joint from behind with a soft hammer.
Unfortunatelly I wasn't so lucky so bought a puller from Halfords, some are very expensive, a £20 job will do fine. Pic of puller set up, I used a socket at the end of the screw thread (between driveshaft and screw thread), use an old socket which is just less in diameter than the driveshaft.
