How to cool down in a 3.2???????
- Thread starter Guest
Back of heat exchangers (near the wheels) on each side are two boxes with rotary flaps - they are supposed to spring load open (as I recall) so that if cable breaks you don' t cook. Check that they are fully open when heater set to cold (if you' re really quick you can set the dial get under the car and watch them move - more relaxing is to get somebody else to move the dial while you watch). You should get away with a good clean up and re-lube but you may need new boxes
Of course it could be something different altogether!
Roy
ClubSport 911
