I have been eyeing up the above kit myself truth be told, and am considering taking the plunge.
With my 944 I had it tested to see whether it held a vacuum (thus seeing if there is a major leak). It did hold vacuum, so the next stage for me will be converting the car to run on R134a.
When I spoke to the AC chap he mentioned that there would be a few things he would do, including:
-adapting the fittings so that they will take the modern clip on fittings which suit R134a systems (the 944 comes with screw on fittings)
-Run a fluid through the system so as to convert and condition the system for R134a (he quoted way more for the fluid than RS2000CUSTOM link).
-From this moment R134a can be added in.
I was quoted around £200 for the above to be done.
However, there have been a few caveats with what has been mentioned above
-The system is meant to be free of any moisture or old gas before the above can be done (I guess with the vacuum test I should be OK).
-PAG fluids are not meant to react well with the above (the cans you buy from Halfords have this as do I guess gas being filled via AC vendors but POA fluid is said to be fine (maybe this was the fluid the above conversion kit has)
-The high side port (the top port I believe in the 944) should not be touched when refilling the system with the system running. Only the low side should be.
-Finally, because IIRC R12 systems ran a lower pressure than R134a systems a retrofilled system can only be filled to 90% of its capacity when compared to if filled with R12. Underfilling can cause damage to the compressor (possibly due to a lack of lubrication) where overfilling can cause seals to blow.
You can get around the above by filling with R12 which will arguably give the best performance (and is also illegal), run a conversion gas (where the cooling effect is diminished) or R134a using the above steps (almost as good as when the car was on R134a).
I shall dig up some links where I found the above information.
