I am planning to retrofit cruise control. As a first step i need to remove the plastic cowl beneath the steering wheel to either modify it (by extending the side opening to take the extra stalk) or replace it. I have removed the 3 torx screws but it's still held in place by an additional plastic stud which evidently holds wiring within the housing and I cannot figure out how to remove it. I have tried compressing it with pliers to force it up through the hole. Anyone know whether there is there something i'm missing or do i need to resort to cutting it off with a stanley knife ?
How to remove lower column switch housing?
- Thread starter red rocket
The instructions just say remove the screws and press off the retaining clip. It shouldn't be that much of a struggle.
Thanks Richard. Sounds easy but isn't and with limited room to move it's hard to see what you're doing. Hopefully i'll figure it out now i know it's supposed to be simple.
Larger diagram. Looks like it is hooked to the top cover.
