How to tell if its Stainless?
- Thread starter Guest
Of course the whole lot is for sale! Complete exhaust less pre-muffler. Make me an offer.
RB
raypollock
raypollock
ClubSport 911
stainless is not magnetic
not always true....depends on how it is treated / what type.... for details, click here
KR's
S
raypollock
The magnet seems to stick to everything more or less the same amount.
One clue may be that the muffler doesn't appear to be painted - in the middle section is the most obvious. It was shiny metal in parts before I started to clean it. I assume that mild steel mufflers come painted and stainless unpainted. Is this correct? Is it just wishful thinking on my part?
RB
carreracat
The easiest way we have found to test steel is if you can find a bit that you can afford to put on a grinding wheel (so probably not suitable if you wanted to use the exhaust again!).
If the sparks are orange it's a hi carbon steel.
If the sparks are light yellow it's mild steel.
If there are hardly any sparks and the grinding wheel gets clogged easily it's stainless.
Alternatively you could try and accelerate oxidation by putting the metal in vinegar or suspending it above and old unsealed car battery so the sulphuric vapour can get to it. Both of these will quickly produce a film of oxidisation if it's mild stell.
At the end of the day its really a case of buyer beware. I want to get rid of it and it will be priced reasonably when the ad appears in 911World. Whoever buys it will get a number of years of good service.
RB
Good stainless does last longer and look much better though. The question is how long you plan on keeping the car and what you want to spend? and can get away with!
Baz
adamtsobek
The best way of determining if an exhaust is stainless is to have a piece analised by a laboratory.
Sorry for the techy nature of the reply but i hope it helps
Adam
