How to tighten bonnet latch?
There seems to be some play in the latch on the bonnet. It feels like it needs adjusting to pull the bonnet down a little more, or is a little play when locked usual?
If not, anyone any ideas about the best way of tightening up?
Hi Tim.
The rubber stoppers in the corners under the leading edge of the bonnet screw in and out. You can adjust the tightness for when the bonnet is closed, by playing with these. That should cure your problem quickly.
