How will it look ?
SECTOR
I have a 1983 2.5 race car currently running 8 inch x 16 design 90 wheels all around, ET53. I am thinking of putting 7 inch x 15 cookie cutters on. I am curious about how it will look, does anyone have any pictures, will it look skinny ?
You get out what you put it. You obviously use spacers or have wide tracked the car. If you use spacers do you intend to remove them or not?
No one can tell you how it will look unless you tell them exactly what youre doing. Early cars regularly ran on ET23 wheels when wide tracked. If you remove the spacers then itll look exactly like any other series one 944. If its been wide tracked or you leave the spacers then itll look like a 1987> car on early wheels - they just fit and it looks quite smart.
I have a set 15" Teledials late offset ET53 with colored center crests if you wanted to swap wheels?
I am in Colchester, if you wanted to try them on see what 15" would like like?
