Hi guys, I have just bought an S2 in black!!, well pleased with her but I have a couple of niggles I wonder if anyone could help.
The first is the clutch is fine but occasionally when the clutch is dipped and I begin to lift the lever it only lifts around 2 inches insead of ts full travel. If I put the clutch back down again it fully disenguages and if I lift it it fully engages. If I then slip my foot under the lever and pull it up it lifts back upto its origional position and works fine again. I was thinking a partially siezed clutch release lever?? What are your thoughts???
The second is when going around an island there is a grumble from the rear of the car, sounding like a wheel bearing. I'm going to check if the exhaust is moving against the body and transmitting noise first but it does sounds like a bearing, could it be a CV joint??
Any replies much appreciated, leeky.
