Last week I was in Ivalo in northern Finland attending the Ice Force course. Ivalo is some 600km north of Helsinki and some 300km inside the arctic circle so gets pretty cold. Ice Force is a truly fantastic experience so what did I enjoy?
1. Firstly you get to drive a wide range of cars including:
A 997 Turbo
A C4 S
A Boxster Spyder
A C2 S
A Panamera Turbo and a C2 S fitted with competition tyres and 8mm spikes
This enables you to compare 4 wheel drive to 2 wheel drive and mid engine with rear engine so is quite a unique experience. I loved the Boxster as it is just like a go kart. The Turbo was a little dissappointing as its additional weight shows up on the ice and you dont really need all that power. The same comments apply to the Panmera. Its a big heavy car. The C 2S fitted with 8 mm studs was fantastic. We drove that car on an elongated oval with long straights. With the additional grip I was seeing over 130kph on the clock before breaking hard and throwing the car into a drift to get round a tight bend only to accelerate along a long straight again. Fantastic fun.
2. Day 2 was rally day
We were taught how to prepare basic pace notes. We then had two laps of a complex circuit to make the notes and then didnt drive the circuit again until after dark so had to rely on the co driver.
Apologies for those that have done some rallying but for those that havnt an explanation may help. You start with each corner being a left or right and then grade it from 1 to 6. 1 being a hairpin and 6 a fast easy corner. You then add information whether you go slower or faster out of the corner and whether it tightens or opens.
In a car the co driver would be saying the following for the above sheet:
50 metres 4right minus into 4left minus long tightens 25 metres caution 2right minus long 25 metres 5 long plus open
Translated this would mean:
After a 50 metre straight gentle right turn with speed decreasing leading into long gentle left which tightens up then 25 metre straight then need for caution as long tight hairpin to the right 25 metre straight into gentle left hander which opens up so speed increasing.
Seems a bit complicated at first but you pick it up very quickly and it really helps in the dark as you can go much faster with the confidenc of knowing whats coming next. The trouble with drifting a car is that the lights are often pointing in the wrong direction.
Porsche organise this event really well. The instructors encourage and push you to your limits and I ended each day exhausted but exhilerated. On rally day we started at 10 and didn't finish until 8 in the evening so you get a lot of driving time. The standard of driving was very high and we had an Ex F1 and Lemans winner on the course so quite a privilege to see those guys at work
Finally you might enjoy this video. Difficult to make the video as conditions are extreme and I was holding a SLR in the passenger seat
http://www.youtube.com/watch?v=K3JxzeOi2QQ
A 997 Turbo
A C4 S
A Boxster Spyder
A C2 S
