andrew_churcher
Hi All,
I just want to see if I can get some assistance on a problem I am having with my S2.
Basically, after I have driven the car for approximately 15-30 mins.......stop the car......come back to it 20 minutes later and go to start it again......the car starts....but idles around 200 rpm.....not up near 900 rpm where it should. It runs like that for a few seconds and either stalls, or after 5 or so seconds perks up to the normal idle (not all the time though). Usually I turn it off and on again and that sorts it out.
The car starts and idles fine from cold, starts and idles fine after I have driven it for 15-30 mins.....turn it off then immediately start it again (checked that today)........it seems to be when its left for a while to cool down then go back to start it that this issue appears to rear its head.
I took it to a specialist for diagnosis and cure last week (amongst other things). Based on the history file with the car, the idle control valve was actioned less than 6mths ago (10/6/09 - less than 4k miles ago) the previous owner probably had a similar isssue. The details from the service invoice are below.
" Collect and deliver car. Check for idle fault, check over basic engine tune, check breather system and air hoses (ok). Strip out remove idle control valve, clean, test and refit. Strip out and remove throttle body, clean housing and throttle butterfly, reset butterfly and refit throttle housing with new allen screws. Check and adjust throttle switch, check CO%.
Upon hooking up the diagnostic equipment and doing some more analysis (after they originally diagnised no problem...which based on the above...i can see how that could happen as the test drive needs to be lengthy and it needs to sit for a while before restarting to replicate the issue) it was decided that the oxygen sensor was giving inconsistent readings and this may be the culprit...so I gave the approval for that to be replaced.
The idle problem described above happened twice today. Turning the car off and then on again seemed to fix the problem and off we went. I just cant understand why it doesnt start properly the first time and idle correctly. Its quite irritating.
I plan to keep the car for a while so I want to rectify issues like this. Its the first chance I have had with the car back to test the work done and so far....doesnt seem to be any better than when I took it in.
On a brighter note - upon returning home i ran into a guy who rents a space in my complex to store his 89 911 carerra. It was a nice machine.....but in seeing the old 944 he was suitably mesmorised that he opened his car door and the 2 bottles of red wine he had just purchase fell out and smashed all over the ground. The effect of a guards red 944 hey!!!
Rgds,
Rgds,
