Idle RPM fluctuating when cold
Is it normal for the idle speed to fluctuate between 500 - 1000 RPM when the engine is cold? all is well once she is warmed up a bit and sits at 500 RPM. Also what is the normal idle speed when at correct operation temp? My OPC have checked the car and say all is well[8|].
Thanx
R
Mine did this today - runs rich in v cold weather for a few seconds and then settles back to normal after 10 secs or so. I don't think there is anything to worry about.
Hi Maurice,
The car was only serviced 1k ago and has been back for other minor issues including the idle problem is the ISV cleaning procedure easy to do as a DIY job? I have looked on p-car.com but have been unable to locate the info can you help?
Thanks in advance
R
