idle up and down
- Thread starter Guest
found it on PET it only has a Porsche part number 944 606 160 00 £189.44 + VAT [:-]
but my local Auto Save says if i can get the Bosch number they will get the part for me half that price
i would like to have the part before i remove the inlet manifold as i dont want to have to refit everything if they dont have one in stock
so if anyone has a Bosch number for one i would be most greatfull
well managed to get the hoses off the idle stabiliser valve BUT it does not fit throught between the inlet manifold
so after a bit of scratching the head desided to remove the inlet manifold sounds simple untill you start and see what else has to come off like the fuel rail, injectors, throttle linkage, fuel lines and some of the air filter ducting but i was glad i had because the previous owners way of doing it has resulted in quite a few cuts in the rubber hoses that conect to the idle valve so a lot of air leaks there
cleaned the valve with carb cleaner and held it accross the battery a it work fine tried to get new hoses but was unable to get them today so came up with the idea of cutting them a bit shorter so you can guess how hard it was to put back together also used jubilee clips to hold the hoses on instead of plastic ties
and here is the Bosch part number if anyone is interested(0 280 140 514)
so the next time i am in there i wander if i extend the hoses would it be possable to reposition the idle stabiliser valve to on top of the inlet manifold or would it fowl the bonnet that would make it a lot easer to clean the next time
a trip to scrap yard to look for hoses sometime me thinks
