I had a roughish idle, which moved +/- 100 around the 900 mark which fluctuated more when hot and would drop quite low.
So I've sprayed carb cleaner into the system while blipping the throttle and also sprayed it down the thinner connecting hose, (the one which joins the large hose underneath), as well as into the throttle itself.
Now there's a stable idle at 1,500 rpm both when hot and cold.
Just wondering, have a got rid of any gook and now simply need to reset the throttle screw, or has the carb cleaner created a leak?
I've looked at the page on Clark's garage, and if I adjust the idle I need to bypass the ISV, by installing a jumper on the diagnostic plug - doesn't say where it is though???
Would it be a good idea to spray silicone spray on different hoses to check for leaks?
Also, where is the idle speed adjuster valve on an '86 Lux?
