Dan944t
Hi guys , just performing a smoke test through my turbo pipes ect to eliminate any boost leaks ect before a tune in near future,…..and i have seen smoke only coming out from the very top of the AOS unit around the edge at the top , where it has the small slots ……just to make it clear this is leaking from the top where the top and side silicone/rubber pipe area and not the top oil cap ,..that’s all fine along with new seals when i rebuilt everything . sure wish i smoke tested back then.
my question is , if applying 14psi of air preasure should this leak at all? i’m assuming it shouldn’t wether under vacume or preasure ?
thanks for any advice known
all the best
Daniel
all the best
Daniel
