Ignition switch/non starter
RayJ
Can Anyone help please.
Car will not start. Battery o.k. all lights and instruments working but when I turn key not a murmur. Will I have to remove switch and if so how? Do I have to drill out the centre of what looks like rivits to do so?
Thanks for reading Ray
A faulty ignition/starter switch doesn't seem to me to be a likely cause of this problem.
If the other things like poor connections already mentioned don't show up anything then I would consider the starter solenoid especially if you get a click but nothing else when you try to crank it. Moisture can get into the solenoids on SCs resulting in corrosion to the internal contacts - a problem I have had on two occasions with my own SC.
If battery and connections look OK and you can put the car on stands you can test that the solenoid is getting 12v via the starter/ignition switch with a volt meter (at the spade connector not the large battery connections). I would do this before tackling the switch. If there's 12v when you try to crank it you will have eliminated problems with the switch and all between. If you can hear/feel the solenoid actuating without the engine cranking I think it's likely to be the solenoid - it's the weak point of the starter.
Another place that can cause increased resistance which is often overlooked is at the earth braid which runs from gearbox to chassis - it's easy to spot but again you will need to put the vehicle on stands to check that.
Best of luck
Hi Phil
Thanks for your help will attempt to access switch as you suggested
Regards Ray
Hi DIJ
Thanks for your suggestion. No clicks from solenoid so will try ignition switch first.
Regards Ray
Ray
Check underside of dash , drivers side.You should see 3 ( if i remember correct) round black connectors that link through the bulkhead.These sometimes work loose push all to ensure they are connected.Had this happen on mine a couple of times.Same symptom all ok but no crank
Note you can knock these with your foot!
Good luck
Geoff
Can agree with that - I lost wipers when one of these came loose some years ago. Very puzzling for a while.
Hi Geoff
Thanks Geoff. I had a poke round under switch and all ignition lights went out so your suggestion could be the answer, when it stops snowing will delve a little deeper.
Thanks Ray
Hi Geoff
Finally managed to work on car, and you were spot on. Thanks very much for your help
Best Regards Ray
