Tom
Has anyone got any advice on the following problem I'm having it seems to be related to the immobiliser but I can't reproduce to investigate. If anyone has any suggestions or experience if a similar problem then please let me know.
In normal everyday use, i.e. commuting 25 miles each way, no problems at all. If I stop the car for a shortish period of time though, e.g to fill up with petrol, the start motor does not operate when I turn the ignition key, even though the immobiliser appears to deactivate as normal.
To be clear, the sequence of events is as follows:
Drive car
Stop and switch off for a while (maybe 5 minutes)
Return to car
Red LED flashing (immobiliser active)
Put dongle in slot, system beeps once
Remove dongle from slot, beeps three times
Relay clicks somewhere over on the passenger side
Red LED now permanently lit
Turn key to start position, LED goes out, starter doesn't operate
As far as I can recall, this is exactly the same sequence as normal, apart from the bit where the engine doesn't turn over.
If I wait for 20 seconds or so, the immobiliser cuts in again (LED flashes) and I repeat the above, the problem persists.
If I leave the car alone for while (maybe 10 minutes or so), the problem goes away and the car starts normally.
I've tried to reproduce the problem at home but so far without success - maybe there is a critical time window (not too short, not too long) where the problem occurs. I think I've had the problem once or twice in the last ten years but has now happened the last three times that I've stopped for around 5 minutes or so.
Any help much appeciated.
Drive car
Return to car
