Immobiliser will not deactivate
shaQ
Hello people,
I have a question which has been bugging me for a week now and I just cant seem to pin point the problem, I have a 944 s2 1990, and for some strange reason when I put the immobiliser key fob into the hole in the steering column the immobiliser will not deactivate the light on the console stays red, this problem is intermittent.
But when I disconnect the battery for 30-60 min and reconnect it the immobiliser deactivates (sometimes).
I have also tried the write up on Clarke's garage the alarm system by-passing but still nothing.
btw before anyone says its my DME relay I replaced it 2 months ago. :)
I have also bought a second hand alarm modual and still nothing!
Any input would be greatly appreciated.
shaQ
ORIGINAL: shaQ
The immobiliser/alarm system in the Clarks is for US only 944's unfortunately[:mad:][:mad:]
ORIGINAL: Diver944
Sounds like a worn immobiliser key or the socket that it plugs into. Replacements are available from http://www.hamilton-palmer.co.uk/ who made the system for Porsche UK to install in our cars when they were imported
[FONT=verdana,geneva"] [FONT=verdana,geneva"]
So is this a common fault with the key fobs? mine does look a tad bashed
I did have a look at the alarm wiring which is behind the glove box and there was this round cylindrical shaped unit which said vecta alarm, was this standard on the 944s I thought they all had Hamilton and palmer? [FONT=verdana,geneva"]
It's not common but it's not unheard of. Twenty years of sliding in and out of the socket can often wear the contacts quite thin so it's hard to make a good contact.
Yours sounds like it has an aftermarket box in there as well just to complicate matters [8|] I'd contact a local alarm specialist if you can't make any progress
