impending doom ?
- Thread starter 75pno
adrian996
An engine with flat cylinders is bound to get the odd bit of engine oil seeping through the piston rings and in to the combustion chamber and this will undoubtedly be the cause of the smoke that you saw (burning oil).
It might well be my imagination but I do seem to get it less since I stated using a 10/40 oil.
Adrian.
uknick
With regard to the smoke on start up, as this is a common question can it be made a sticky e.g. in the "Mechanical" forum?
On the Carrera, I found that using a 5W-40 oil helped almost eliminate it, so I would agree with Adrian. On the Turbo I also use a 5W40, but I think I will try a 10W-50 when I have used up my stock of 5W-40.
Paul James
adrian996
If you are in any doubt I would go and check it out with you local indi. That should reassure you.
Adrian.
Paul James
