Guys,
here is a more relaxed view on RMS that just came on the renlist boxster email ring
Subject: RMS...
Date: Fri, 24 Dec 2004 07:05:48 -0500
X-Message-Number: 1
Not meaning to sound too frank, but.... Porsches have more or less = always leaked oil. There are three kinds of RMS leaks. =20
1. Damp or wet seal, that you don't fix right away. This is where you = see oil, and the motor gets wet, and you drip a drop here and there. You = fix this one when you need a clutch.
2. A dribble seal, that leaks enough oil to leave puddles and have you constantly checking your oil level, and adding oil. This one, is beyond = an annouyance, and you need to fix it. There is a chance, that Porsche = will say your engine case is out of spec and you need a new engine. In = warranty, this isn't a problem. Out of warranty, you need to spend your money and take your chances.
3. The sell your car leak, is when you have fixed a wet seal or a = dribble seal, and it doesn't stay dry enough to keep you happy with your car, so = you sell it. (or worse, fix it again, and sell it quick before it leaks =
again)
As far as I'm concerned. This RMS talk is way overplayed. Of all the Boxsters I know, only one has had needed RMS, under warranty, and was = never talked about again. What is annoying about the RMS is it is 800 - 1000 labor for a $5 (or $25) part. =20
Now that you 'need' special tools to check and install a RMS, everyone = is 'supposed' to goto the dealer to get their work done. =20
This RMS problem is no different than any air cooled Porsche or VW the = past 40 years. If it leaks, when you put a clutch in, you put a new seal in, = if it leaks again, you have to learn how to live with it, or sell the car.
