Improving eleccy windows performance
- Thread starter zcacogp
peanut
I reckon it would be a lot of work to improve a 944. You'd have to remove the motor and get it serviced or replace with a newer unit and grease up all the linkage maybe put new felt guides in would help a lot too. Perhaps there is a faster stronger motor drive system from another Piggy that would fit ? It would be worth all the work then
will lyons
Wil
morris944s2john
Fred Hindle
Lubricate the runners / guides for the windows (hair shampoo works well - dont use washing up liquid as that contains salt)
Clean all contacts.
"The installation is the reversal of the removal procedure"
Spray liberally with WD40 once windows are back together.
Replace door cards.
Take car for test drive to ensure correct operation.
Thanks - lots of good ideas there. I can believe that they were slow from new, but time and dirt will have taken their toll. Fred - good ideas for cleaning it up, thanks. I'll try that when I have a spare Saturday. (An aside - are you sure that hair shampoo doesn't contain salt? I thought it did ... )
Wil - replacing the motors with Ford ones? Now that's an interesting thought ... Thanks.
Fred Hindle
If it does then it is certainly a lot less than washing up liquid. (My hair never smells salty after I've washed it!)[
Alan's suggestion of using silicon spray is a good alternative though.
Cheers,
Fred Hindle
Do you use Zymol or Turtle Wax?
Cheers,
