James Shunt
Here's my recent windscreen/rust experience in case it helps any fellow owners.
I had a stone chip my windscreen a week ago - v loud and scary - on the M6. I thought it was a repair job but the guy from my insurer (Admiral/RAC Autowindscreens) said it may be an MOT failure (eye level but just on the driver's side of the aerial). He said it was best to replace so I had to take it to the workshop.
There, the guys said fixing the chip may well be OK but I could choose (free repair vs £50 excess for new screen). They also pointed out the few, small bubbles of rust I have in the usual places around the windscreen and planned to sort out in a few months' time - "we can't see what it's like underneath until the screen is out," they said. Having come this far, I opted for a new screen (they cost £385, apparently).
Sure enough, once the screen was out the rust underneath was much worse than you'd expect from seeing the outside of the car. There was a small hole in the surround too and RAC Autowindscreens' chaps were sure a rust repair and/or windscreen replacement had been bodged by a previous owner. Nothing dangerous, but it would have been best for me to have everything fixed in one go. I was left to choose between:
- the windscreen guys adding some anti-oxidant and patching it up, then getting the rust fixed by a specialist later but with the risk that the screen may break when it is taken out;
- paying to truck the car to a body shop while the screen was out, sorting out the rust and getting it back to the windscreen workshop. Admiral wouldn't help with the cost of trucking, unsurprisingly.
I decided to patch it up as a trusted body shop couldn't fit me in quickly. I suppose the conclusions could be these.
- If there are rust bubbles then it's likely to be worse than you'd expect underneath as mine looked trivial... until the screen was out. The water collects out of sight and does a lot of hidden damage.
- If at all possible, be sure to see your car with the windscreen out if you are getting any work done that requires it. Only then can you see the extent of the rust or the quality of any repair because once it is fitted, the screen can hide bodge-jobs and all sorts.
James
James
