This could prove intersting
test for boost/vacuum leaks and lose them. (arnworx do a nice tester and throttle body seal kit).
I would reccomend the wastegate as a good starting point. The standard one is poor and worse still with age.
With this you will need a boost control device of some kind. A MBC works but most end up going to an electronic bost controller of some kind so why pay twice?
Once you have a wastegate it is important to have a boost guage to monitor the boost level, go too high with the standard chips and the protection circuits may cause issues. You also do not want to run too much boost until you have the fuel to match (see also narrow and wideband below)
New Chips will allow you to run more boost (relatively) safely by altering your ignition advance and fuelling. Dependant how much boost you want to run (and choice of turbo) will demand how much fuel you need which will decide wether you want larger injectors, an uprated Fuel pressure regulator, a high flow fuel pump.
In theory custom chips should be better (burnt for your car) but we have seen good results with off the shelf items which are cheaper as the dyno time is spread over lots of cars.
An alternative to new chips in your standard engine brain is standalone managment which will allow lots more options and flexibility. The purchase price will be higher but it will offer greater flexibility and room for development with easy addition of MAF/MAP air flow sensing (less restricitive) much more adaptability to further tuining, if you add cams, intakes, coil on plug etc.
Once you start increasing boost levels changing the fuelling it is important to kow the air/fuel mixture is safe (not lean), A narrow band guage and 3 wire sensor (fitted to cat equipped cars as standard) will give you a rough guide when the mixture is close, A wideband will work over much larger ranges and provide better information but they cost more. My current favourite (though I havent bought on yet) is the PLXr500 which allows Exhaust gas temp, knock sensing, and has a G sensor so you have a guide to performance.
MAF or MAP will replace the 'barn door' air flow meter allow less intake restrictions so better driveability / response and top end increases.
My favourite choice currently without going standalone is the vittesse MAF - I bought one, it comes with a chip board to replace the ecu chip and a selection of maps. A piggyback is available so you can fine adjust the fuelling but it is specced oversize so it measures airflow at wide open throttle thus you can change the boost levels and it can adapt (within parameters - go too high and detonation (knocking may occur) and you may max out your injectors and go lean).
Atermarket MAP that works with the standard ECU is harder to find.
The AFM and some other MAFs mimic the standard barn door which is maxxed out at around 3,500 rpm (wide open) then they rely on preset information on the chip (expected boost level / flow characteristics) and so are not as flexible - not really a proplem with standalone but with the standard ecu you may need new chips as boost level changes or you do other mods.
A different turbo will allow more flow, and better efficiency, go too large and it will be laggy at low revs but produce lots of top end power, too small it will be out of its efficiency range at high rpm and produce heat and not much more, less lag though. Design and bearing type will also have an effect. Some turbos are not as well made as others - check with your local re-builder and see which housings are in the bin full of cracks.
I think it is important to have knock monitoring the standard system only can retard the ignition iirc 6 degrees, which may not be enough especially if you are running over 18psi of boost. With higher boost and outputs you are running closer to the limits of safety.
Additional items which will help
Exhaust - an aftermarket exhaust should flow better.
Intercooler - should be more efficient allowing better flow and cooler charge air.
New hard pipes to match the flow abilities of the intercooler.
Head gasket I prefer the sandard item - it should handle extra boost and I believe provided the car is set up right it is up to the task.
Larger capacity should improve the low down torque and ability to generate boost. The smart solution as in Divers avatar uses interlocking pieces to strengthen the top of the block. I imagine the standard bores looking like rocket nozzles at high temps and boost - flexy!
etc.
Finally what I did
Boost enhancer
Turbo - mine had failed, rebuild as a hybrid wasnt too much more K27/8 with J boot adaptor pipe and DF coolant adaptor
Ess exhaust and cat delete.
Boost guage and narrow band
Guru 15 psi Chips, wastegate shims, 3 bar FPR, reliaboost. (delete BE)
Guru 18psi chips, tial wastegate, reliaboost
55lb injectors, EBC profec Bspec1 (delete reliaboost), 9XX (jon Mitchell) chips, SPS refurbed head, 9xx Fuel pump
Vitesse MAF and chip board (delete 9XX chips and standard AFM)
So current spec
Vittesse MAF and chips kit, 3 bar bosch FPR, 9xx fuel pump, SPS head, Greddy profec spec B type 1, 55lb injectors, Not had it on the rollers since finding a big boost leak, but prior to that it was close to 350BHP 350 ftlbs, I believe it might have just made it now at 18psi.
Next steps will be wideband, piggy back for the maf kit, uprated intercooler and hard pipes and knock detection / big red warning light
One of Simons very nice turbos - cant decide to do it now and sell the current turbo or wear it out and then do it,
Hope that helps
Tony
