Indicator Arm broken
skendrick
Hi all,
My indicator arm has just broken internally.
The indicators still work but the arm will not stay up when indicating right, stays down when indicating left but will not turn itself off.
Are they easy to fit and is it best to go through OPC?
Is it a 2, 3, or 4-lever stalk? If it is 2 or 3 lever, then you could try my friend Tony at www.wrightune.co.uk . He has a few that he removed from 996's when he does cruise and OBC retrofits. No doubt they would be much cheaper than a new one from an OPC (£180-ish).
